[GRASS-user] Re: Ongoing r.in.wms issue
Hamish
hamish_b at yahoo.com
Wed Mar 5 21:42:10 EST 2008
Richard Chirgwin wrote:
> Previously you had asked me to supply the output with debug set. I
> think I had sent something, but in case I forgot
no, I just have had too much to do & the volunteer work has to take a
low priority sometimes.
> (office moves are very disruptive),
yeah, tell me about it...
> here is all the debug information that popped out:
> D1/1: -n
> Everything else is as you have seen before...
yeah, I had hoped it would have been a bit more informative. But that
is something to go on I guess, ie there is nothing else on the line
after the mysterious -n.
> - this is in line 437 of r.in.wms as it is now on trac.osgeo.org
> - it's on line 118 of wms.download
is this using updated versions of all the files in the
scripts/r.in.wms/ from this morning? i.e. including yesterday's
commits?
http://trac.osgeo.org/grass/browser/grass/trunk/scripts/r.in.wms
> Unfortunately, I am not a programmer - not even a script programmer -
> and can't understand
in this case having it as a script actually makes the thing harder to
understand than if it were in a real programming language.
and even then r.in.wms is a bit dense.
> why eval "$line" is a problem on a Leopard machine but not on an
> OSX 10.4 machine.
? a change in a BSD helper app (awk, head, wc, etc.) ?
I only have OSX 10.4 to test with.
Ok -- to get full script debug output please change
#!/bin/sh
to
#!/bin/sh -x
at the top of each script (or '#!/bin/bash -x' as needed..)
then rerun.
then you should get all sorts of detailed output. Can you copy that
output in a file (compress if it's too huge) and send to me?
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
