[GRASS-windows] Re: [GRASS-user] Xming as X server for winGRASS?
Luigi Ponti lponti at infinito.it
Thu Mar 13 18:24:47 EDT 2008
Dear Paul and Glynn: thank you very much for your feedback.
Glynn Clements wrote:
> The problem with using monitors on native Windows isn't the graphics,
> it's the client-server communication.
OK: hopefully I won't bother the list any longer on X-monitors.
> If the environment variable GRASS_RENDER_IMMEDIATE is set to TRUE, PNG
> or PS, all d.* commands write graphics directly to a file, without
> using a monitor.
> The filename, format and dimensions are set by environment variables,
> as described at:
> 	http://grass.ibiblio.org/gdp/html_grass63/variables.html#png
> 	http://grass.ibiblio.org/gdp/html_grass63/variables.html#ps
> All of the functionality of the PNG and PS drivers is available in
> this way.
This works fine in my Cygwin/grass6.2.2 installation, although the
GRASS_PNG_READ variable does not seem to be available in grass6.2
http://grass.ibiblio.org/gdp/html_grass62/pngdriver.html so the overlay
thing suggested by Paul wouldn't work.
Trying the same with native winGRSSS 6.3.0 RC5 is less of a success: (1)
no way to set environment variables via the GUI Output - GIS.m window;
(2) not able to start GRASS via cmd.exe as suggested at
http://grass.gdf-hannover.de/wiki/WinGRASS_Current_Status
by typing the following at the cmd.exe prompt:
    C:\grass63RC5\bin\grass63.bat -text
I get the output below:
    Welcome to GRASS 6.3.0RC5 (2008)
    GRASS homepage:                          http://grass.itc.it/
    This version running thru:               Windows Command Shell (cmd.exe)
    When ready to quit enter:                exit
    Help is available with the command:      g.manual -i
    See the licence terms with:              g.version -c
    "cmd.exe" non è riconosciuto come comando interno o esterno,
     un programma eseguibile o un file batch.
(the Italian error message would sound more or less like: "cmd.exe" is
not recognized as an internal or external command, an executable program
or a batch file.)
Thanks again for your time and insights,
Luigi
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080313/981aa997/attachment.html
