[GRASS-user] v.distance warning (WARNING: more cats of to_layer)
Corrado
ct529 at york.ac.uk
Fri Mar 14 06:01:26 EDT 2008
Dear Martin,
does that mean that there are several areas (that is more than one) in the to
vector that satisfy the condition (for example: dmax=100) for each point in
the from vector?
On Wednesday 12 March 2008 15:23:46 Martin Landa wrote:
> Hi,
> in your case the vector map (given as 'to' in v.distance) contains
> some areas (bunch of boundaries and centroid inside). Category number
> of area is assigned to the centroid. Geometry feature (point, line,
> boundary, centroid, face or kernel) can have more categories in
> general. The message from v.distance warns you that there are more
> categories assigned to the area (i.e. centroid) in given layer
> (to_layer). The last found category in given layer is taken for
> computation, maybe v.distance should be fixed to handle also multiple
> categories in one layer(?)
> Martin
> 2008/3/12, Corrado <ct529 at york.ac.uk>:
> > Dear Martin,
> > I do not understand what you mean. Could you please explain?
> > On Wednesday 12 March 2008 14:09:46 you wrote:
> > > Hi,
> > > it means that given vector feature from 'to' map (layer 'to_layers')
> > > has more then one category. Maybe it would make sense to change
> > > warning text to something less cryptic.
> > > Martin
> > > > Dear Martin,
> > > > I am using 6.2.3.
> > > > On Wednesday 12 March 2008 13:31:49 you wrote:
> > > > > Hi,
> > > > > > what does the warning:
> > > > > > WARNING: more cats of to layer
> > > > > > mean, when you execute the command v.distance?
> > > > > which GRASS version are you using? I cannot find such kind of
> > > > > message in grass_trunk.
> > > > > Martin
> > > > Best Regards
> > > > Corrado Topi
> > > > Global Climate Change and Biodiversity
> > > > Area 18,Department of Biology
> > > > University of York, York, YO10 5YW, UK
> > > > Phone: + 44 (0) 1904 328645, E-mail: ct529 at york.ac.uk
> > Best Regards
> > Corrado Topi
Best Regards
Corrado Topi
