[GRASS-user] v.distance warning (WARNING: more cats of to_layer)
Martin Landa landa.martin at gmail.com
Fri Mar 14 06:17:37 EDT 2008
it means that some of areas have multiple assigned categories, try to
open with v.digit and check categories of area centroids.
or print categories using v.category module, e.g.
v.category map type=centroid option=print layer=1
where layer is same as to_layer from your v.distance calling (probably 1)
you will find some multiple categories, e.g.
24
25
21/22/23/24/28
29
In this case v.distance use only cat '28' (last found).
Martin
2008/3/14, Corrado <ct529 at york.ac.uk>:
> Dear Martin,
>  does that mean that there are several areas (that is more than one) in the to
>  vector that satisfy the condition (for example: dmax=100) for each point in
>  the from vector?
>  On Wednesday 12 March 2008 15:23:46 Martin Landa wrote:
>  > Hi,
>  > in your case the vector map (given as 'to' in v.distance) contains
>  > some areas (bunch of boundaries and centroid inside). Category number
>  > of area is assigned to the centroid. Geometry feature (point, line,
>  > boundary, centroid, face or kernel) can have more categories in
>  > general. The message from v.distance warns you that there are more
>  > categories assigned to the area (i.e. centroid) in given layer
>  > (to_layer). The last found category in given layer is taken for
>  > computation, maybe v.distance should be fixed to handle also multiple
>  > categories in one layer(?)
>  > Martin
>  > 2008/3/12, Corrado <ct529 at york.ac.uk>:
>  > > Dear Martin,
>  > >  I do not understand what you mean. Could you please explain?
>  > >  On Wednesday 12 March 2008 14:09:46 you wrote:
>  > >  > Hi,
>  > >  > it means that given vector feature from 'to' map (layer 'to_layers')
>  > >  > has more then one category. Maybe it would make sense to change
>  > >  > warning text to something less cryptic.
>  > >  > Martin
>  > >  > > Dear Martin,
>  > >  > >  I am using 6.2.3.
>  > >  > >  On Wednesday 12 March 2008 13:31:49 you wrote:
>  > >  > >  > Hi,
>  > >  > >  > >  what does the warning:
>  > >  > >  > >  WARNING: more cats of to layer
>  > >  > >  > >  mean, when you execute the command v.distance?
>  > >  > >  > which GRASS version are you using? I cannot find such kind of
>  > >  > >  > message in grass_trunk.
>  > >  > >  > Martin
>  > >  > > Best Regards
>  > >  > >  Corrado Topi
>  > >  > >  Global Climate Change and Biodiversity
>  > >  > >  Area 18,Department of Biology
>  > >  > >  University of York, York, YO10 5YW, UK
>  > >  > >  Phone: + 44 (0) 1904 328645, E-mail: ct529 at york.ac.uk
>  > >  Best Regards
>  > >  Corrado Topi
>  Best Regards
>  Corrado Topi
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
