[GRASS-user] wxpython problems
Dr. Manuel Seeger seeger at uni-trier.de
Mon Mar 17 06:21:24 EDT 2008
Hello all,
I just downloaded the recent 6.3.svn.
There I wanted to start using the wxpython-gui.
After make I get the following message:
Errors in:
/home/seeger/grass_trunk/gui/wxpython/vdigit
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
I follow the instructions, and then:
/usr/bin/ld: cannot find -lgdi
collect2: ld gab 1 als Ende-Status zurück
make: *** [_grass6_wxvdigit.so] Fehler 1
What can I do?
I would like to test it!
Best regards
Manuel
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent 			Scientific Assistant
Physische Geographie 			Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften 	Geography/Geosciences
Universität Trier			University of Trier
D - 54286 Trier
Tel.:	+49-651-201 4557
Fax:	+49-651-201 3976
Web:	http://www-neu.uni-trier.de/index.php?id=9607
