[GRASS-user] wxpython problems
Martin Landa
landa.martin at gmail.com
Mon Mar 17 06:36:28 EDT 2008
2008/3/17, Dr. Manuel Seeger <seeger at uni-trier.de>:
> Errors in:
> /home/seeger/grass_trunk/gui/wxpython/vdigit
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
this error affects only digitizer, not wxGUI itself.
> I follow the instructions, and then:
> /usr/bin/ld: cannot find -lgdi
> collect2: ld gab 1 als Ende-Status zurück
> make: *** [_grass6_wxvdigit.so] Fehler 1
> What can I do?
Did you run ldconfig after you created link to /usr/local/lib?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
