[GRASS-user] r.in.xyz
Hamish hamish_b at yahoo.com
Wed Mar 19 02:18:14 EDT 2008
Glynn:
> If you have a "sparse" set of points, import them as a vector map then
> use v.surf.rst. I'm not sure if r.fillnulls[1] handles sparse maps
> (islands of individual cells), or whether it's limited to filling
> small "holes" in mostly-filled maps.
> [1] r.fillnulls is a script which uses v.surf.rst for the
> interpolation.
r.fillnulls is intended to to fill small "holes" in mostly-filled maps.
It creates points from a few cell buffer around each hole then
interpolates across the gap.
The r.in.xyz help page has some tips on making a surface from input
points. For less than a million or three input points v.in.ascii +
v.surf.rst is probably the better way, unless you want to use r.in.xyz as
a statistical noise filter.
r.surf.* modules could work too, to various levels of worseness versus
what v.surf.rst can do.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
