[GRASS-user] r.in.xyz
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Mar 19 09:20:18 EDT 2008
On Tue, 2008-03-18 at 23:18 -0700, Hamish wrote:
> Glynn:
> > If you have a "sparse" set of points, import them as a vector map then
> > use v.surf.rst. I'm not sure if r.fillnulls[1] handles sparse maps
> > (islands of individual cells), or whether it's limited to filling
> > small "holes" in mostly-filled maps.
> > [1] r.fillnulls is a script which uses v.surf.rst for the
> > interpolation.
> r.fillnulls is intended to to fill small "holes" in mostly-filled maps.
> It creates points from a few cell buffer around each hole then
> interpolates across the gap.
It's clear now. I think a bit more reading before posting doesn't hurt.
> The r.in.xyz help page has some tips on making a surface from input
> points. For less than a million or three input points v.in.ascii +
> v.surf.rst is probably the better way, unless you want to use r.in.xyz as
> a statistical noise filter.
Any infomation somewhere about "filtering" noise with r.in.xyz?
> r.surf.* modules could work too, to various levels of worseness versus
> what v.surf.rst can do.
> Hamish
> ____________________________________________________________________________________
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
