[GRASS-user] v.db.select works, db.select fails: same mapset,
same VAR
Wailliez Sébastien
sebastien.wailliez at trasys.be
Wed Mar 19 08:30:42 EDT 2008
Hello,
any idea why v.db.select works while db.select fails when invoked from inside the same mapset?
I call db.connect -p before calling (v.)db.select and get:
driver:odbc
database:3drov
schema:(null)
group:(null)
This all works fine for v.db.select but db.select fails with an error message. My version of GRASS is 6.2.3 and the error message reads:
DBMI-ODBC driver error: SQLConnect():
[UnixODBC]FATAL: role '' does not exist (210)
Now, I am pretty confident that unixODBC is correctly configured on my Linux box as I have C code that works with the same DSN (3drov) and also, obviously, because v.db.select manages to connect to my database through the same DSN. I also made sure that the 3 in the name 3drov is not the source of the problem, but I'm now totally clueless.
Any idea why? Thanks in advance!
Sébastien E. Wailliez
Software Engineer
Trasys Space - Consulting & Solutions
Terhulpsesteenweg 6C
B-1560 Hoeilaart - Belgium
Office: 2K22
Tel: +32 2 773 75 64
Fax: +32 2 773 79 30
Email: sebastien.wailliez at trasys.be
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080319/9ba27585/attachment-0001.html
