[GRASS-user] v.db.select works, db.select fails: same mapset,
	same VAR
    Markus Neteler
    neteler at osgeo.org
    Wed Mar 19 09:15:32 EDT 2008
Sébastien,
could you try ogrinfo on that data set? Just to see if it also
fails. Should be something like
ogrinfo ODBC:user/pass at DSN table
Markus
On Wed, Mar 19, 2008 at 1:30 PM, Wailliez Sébastien
<sebastien.wailliez at trasys.be> wrote:
> Hello,
> any idea why v.db.select works while db.select fails when invoked from
> inside the same mapset?
> I call db.connect –p before calling (v.)db.select and get:
> driver:odbc
> database:3drov
> schema:(null)
> group:(null)
> This all works fine for v.db.select but db.select fails with an error
> message. My version of GRASS is 6.2.3 and the error message reads:
> DBMI-ODBC driver error: SQLConnect():
> [UnixODBC]FATAL: role '' does not exist (210)
> Now, I am pretty confident that unixODBC is correctly configured on my Linux
> box as I have C code that works with the same DSN (3drov) and also,
> obviously, because v.db.select manages to connect to my database through the
> same DSN. I also made sure that the 3 in the name 3drov is not the source of
> the problem, but I'm now totally clueless.
> Any idea why? Thanks in advance!
> Sébastien E. Wailliez
>  Software Engineer
>  Trasys Space - Consulting & Solutions
>  Terhulpsesteenweg 6C
>  B-1560 Hoeilaart - Belgium
>  Office: 2K22
>  Tel: +32 2 773 75 64
>  Fax: +32 2 773 79 30
>  Email: sebastien.wailliez at trasys.be
>  grass-user mailing list
>  grass-user at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/grass-user
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
