[GRASS-user] v.centroids question
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Mar 19 15:53:07 EDT 2008
On Wed, 2008-03-19 at 12:12 -0700, John C. Tull wrote:
> On Mar 19, 2008, at 11:08 AM, Nikos Alexandris wrote:
> >> John,
> >> maybe you could try
> >> v.clean with type=line,boundary,centroid,area tool=snap,break,rmdupl
> >> thresh=.01
> >> Not sure but I suspect the "break" tool is what you might need.
> > And then of course the rest with v.centroids
> Nikos,
> Thanks for the suggestion. I seem to be getting closer. I ran v.clean
> as you suggested, then ran v.clean with tool=chdangle and a really big
> threshold value.
Ah.. ok!
> Now many more areas are available, but there are
> still quite a few apparently closed polygons that are not being picked
> up as areas. I'm playing around with different thresholds for snap and
> various permutations of the various operations.
So, if I understand, the idea is:
lines to boundaries (v.type) > snap (close open boundaries) + chdangle
(dangles from boundary to line) > v.centroids
Maybe I misunderstood the "break" tool here. I thought it would help but
maybe it's irrelevant (?)
If it's not too much work could you copy-paste your commands (if
successful)?
Thank you,
Nikos
