[GRASS-user] modify feature's values interactively
Martin Landa
landa.martin at gmail.com
Wed Mar 26 14:46:57 EDT 2008
Hi
2008/3/26, Moritz Lennert <mlennert at club.worldonline.be>:
> >> is it possible within GRASS to modify feature's values (of the feature
> >> attribute table) interactively (e.g. like in ArcGIS, where I can select an
> >> object within the view which then can be modified/removed...)?
> > you mean to modify attribute data of vector objects? If so, yes, you
> > can use v.digit or digitizer in wxPython GUI (experimental).
Moritz:
> IMHO there should be a solution outside of the digitizer (i.e. without
> risking any alteration of the actual map), something along the lines of
> "d.what.vect -e".
> Christian, if this is what you need, you will have to use it with the
> "old-style" x-monitors from the command line, i.e.:
> d.mon x0
> d.vect YourMap
> d.what.vect -e YourMap
> This is typically one element which would be GUI-only as I don't think
> it would make much sense to program an interactive command line version...
> So maybe something to think about for wxgrass.
hm, it wouldn't be so difficult to implement, sorry, back to the
reality;-) Basic implementation is here
http://trac.osgeo.org/grass/changeset/30745
see
http://grass.gdf-hannover.de/wiki/Image:Wxgui-vector-querying-gnulinux.png
Regards, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
