[GRASS-user] a beginners question
Gazz1982
garynobles at yahoo.com
Sun Mar 30 06:57:43 EDT 2008
That doesn't seem to work,
Here is my directory structure under grass
bin
bwidget
docs
driver
etc
fonts
include
lib
scripts
I copied the r.horizon2 folder into the bin directory and tried to make it
it returned the same error
I have superuser/root permissions
I'm sure when i do it once I will be able to do it again and again!
Thanks for your help
there isn't an imagery or raster folder should I make one in the grass
directory?
Nikos Alexandris wrote:
> On Sat, 2008-03-29 at 16:20 -0700, Gazz1982 wrote:
>> I have just been converted to Linux after struggling with cgywin!
>> How do I install a new grass module, in this case I have the file
>> r.horizon2.tar.gz on my desktop and my $GISBASE is /usr/lib/grass
> (You might need to be superuser/root to do "make install" in the end)
> In general it must be something like:
> 1. copy "add-on" directory to /where/your/grass/source/is under the
> respective generic module category
> e.g. for i.pr it would be:
> cp -r i.pr /where/your/grass/source/is/imagery/
> 2. configure grass
> cd /where/your/source/is/
> ./configure #with your parameters
> 3. go to the "add-on" directory and "make it"
> e.g.
> cd /imagery/i.pr
> make
> 4. back to grass source directory
> make install
>> I've done this before but I can't remember the commands and where
>> everything
>> should go
>> Thanks
> Hope this helps (as it helped me once when somebody told me how make it)
> Cheers,
> Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/a-beginners-question-tp16370225p16380608.html
Sent from the Grass - Users mailing list archive at Nabble.com.
