[GRASS-user] ERROR: Database connection not defined
Moritz Lennert
mlennert at club.worldonline.be
Mon Mar 31 11:22:30 EDT 2008
On 31/03/08 16:39, Jose A. Ruiz-Arias wrote:
> Dear list,
> after importing a tab file formatted with columns xutm, yutm and cat
> using v.in.ascii, I have try v.db.select against this vector and the
> next error appeared:
> 'ERROR: Database connection not defined'
> This is a bit odd for me considering that I remember some weeks ago I
> created with v.in.ascii other point vectors from tab files formatted
> like this and v.db.select worked properly. Someone could advise me?
From the v.in.ascii man page:
"Attribute table is only created if it is needed, i.e. when at least one
attribute column is present in the input file besides geometry columns."
Moritz
