[GRASS-user] Fixing Collared DRGs
Tom Russo
russo at bogodyn.org
Mon Mar 31 18:31:04 EDT 2008
On Mon, Mar 31, 2008 at 03:00:41PM -0700, we recorded a bogon-computron collision of the <dhirsch226 at gmail.com> flavor, containing:
> Hi folks- I'm new to GRASS, but am eager to learn a GIS that doesn't require
> me to use Windows. I can manage to do the basics with GRASS (although I'm
> having trouble with the python GUI, but that's another story). What I'm
> trying to do now is remove white collars from some GeoTiff topo maps I got
> for an area in Montana (my region of interest overlaps the corners of four
> quadrangles). These have white borders, and the border region is the same
> white as the white of the map itself (color index 1). When I downloaded the
> maps, there was a link to some scripts (for ArcMap) to remove the collars,
> and I imagine that there is some equivalent way to do it for GRASS.
> I'm running GRASS 6.3.0RC5 (using the X11 tcltk interface) on a PowerMac G4.
> Thanks,
It is a little tedious but not especially difficult, and easily scripted.
Here's how I do it:
Go to www.geocomm.com and download their 24kgrid.shp "quad index" file. It
contains the lat/lon rectangles for all the USGS 7.5' DRGs in the whole US.
Extract the set of outlines for your state to a shapefile:
ogr2ogr -where "STATE='MT'" montana_quads.shp 24kgrid.shp
Now you need to translate those outlines to the UTM zone and datum that your
maps are in. Some states use quad maps all in NAD27, some have a mixture of
NAD83 and NAD27 maps. The 24kgrid shapefile has no associated .prj file,
and just contains the lat/lon boundaries of the quads (inside the neatlines).
If your GRASS location is UTM zone 12, NAD27 (and your DRGs are also NAD27,
UTM zone 12), you could do this:
ogr2ogr -t_srs EPSG:26712 -s_srs EPSG:4267 montana_quads_UTM12_NAD27.shp montana_quads.shp
This reprojects the (assumed) NAD27 lat/lon rectangles into UTM Zone 12/NAD27
polygons. These will be used to clip the collars off of DRGs.
Then import this shapefile into your GRASS location with v.in.ogr:
v.in.ogr dsn=montana_quads_UTM12_NAD27.shp output=quads27
Once you've done that, you're ready to collar-clip all the NAD27 DRGs you want.
Say you have a quad for Abbot Lake, MT that's called o48112d2.tif. You could
then do this:
r.in.gdal input=o48112d2.tif output=o48112d2_withcollar
v.extract where="MRC='48112-D2'" input=quads27 output=o48112d2_bounds
(this selects only the single quad outline applicable)
g.region rast=o48112d2_withcollar # this just to set resolution properly
g.region vect=o48112d2_bounds # to set the region only to neatline
v.to.rast input=o48112d2_bounds output=o48112d2_bounds use=val value=1
(this one generates a raster that's 1 inside the neatline, null outside)
echo "o48112d2_withoutcollar=if(!isnull(o48112d2_bounds),o48112d2_withcollar,null())" | r.mapcalc
(this populates the _withoutcollar map only where the mask is non-null)
(you could also do it with
r.mask input=o48112d2_bounds
echo "o48112d2_withoutcollar=o48112d2_withcollar"| r.mapcalc
r.mask -r
r.colors map=o48112d2_withoutcollar rast=o48112d2_withcollar
(to copy colormap from original)
If the location is in a different datum than the DRG, I add a couple steps. For
example, if my location is in NAD27 and the DRG is in NAD83, I'd do this:
ogr2ogr -t_srs EPSG:26712 -s_srs EPSG:4269 montana_quads_UTM12_NAD83.shp montana_quads.shp
this creates a NAD27/UTM Zone 12 shapefile of the outlines of NAD83 quad maps.
I'd then import this as, say, "quads83" with v.in.ogr, and the steps would be:
gdalwarp -t_srs EPSG:26712 o48112d2.tif o48112d2_NAD27.tif
r.in.gdal input=o48112d2_NAD27.tif output=o48112d2_withcollar
v.extract where="MRC='48112-D2'" input=quads83 output=o48112d2_bounds
ull())" | r.mapcalc
r.mask -r
Only the first three steps are different.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
