[GRASS-user] Use GRASS as a web-application?
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sat May 10 08:43:38 EDT 2008
On Sat, 2008-05-10 at 12:26 +0200, G. Allegri wrote:
> Also, take a look to the "Recent Earthquakes: map generated by GRASS
> on the fly with PHP" example:
> http://grass.itc.it/spearfish/php_grass_earthquakes.php
> Giovanni
> 2008/5/10 Paul Kelly <paul-grass at stjohnspoint.co.uk>:
> On Sat, 10 May 2008, Jachym Cepicky wrote:
> Hi,
> http://pywps.wald.intevation.org is here for this
> purpose
> if you prefer java, look after 52north wps
> implementation
> Also, GRASS-links at http://pnwpest.org/glinks/ is a much
> older implementation that was somewhat ahead of its time -
> probably only of interest for historical reference purposes
> but it seems to still work. I'm not sure which version of
> GRASS that demo implementation runs on but I suspect it is
> 4.x. It might be updateable to use more recent versions
> though. Depends on what you need I suppose.
> Paul
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Thank you all!
Dear Nebosja,
I think these links should be enough. Don't hesitate to contact again
about questions concerning GRASS.
