[GRASS-user] Multiple usage of r.water.outlet
Michael Barton michael.barton at asu.edu
Thu May 15 11:25:35 EDT 2008
If you run g.region to set the computational region to just the area of each
basin before doing the other calculations, it might run a lot faster.
Michael
On 5/15/08 5:02 AM, "grass-user-request at lists.osgeo.org"
<grass-user-request at lists.osgeo.org> wrote:
> Date: Thu, 15 May 2008 14:00:14 +0200
> From: Christian Schwartze <Christian.Schwartze at uni-jena.de>
> Subject: [GRASS-user] Multiple usage of r.water.outlet
> To: grass-user at lists.osgeo.org
> Message-ID: <1210852814.482c25ceebafb at webmail.uni-jena.de>
> Content-Type: text/plain; charset=ISO-8859-1
> Dear GRASS user,
> the problem I have is using r.water.outlet for some scripting in Python. Below
> I
> want to explain the proceeding in detail. It should be mentioned in advance
> that
> the necessary drainage raster has nearly 10000 rows and columns, so it's not
> really small...
> I have a point shape file (or generally point coordinates, more than 100
> pairs)
> that presents the input for multiple calls of r.water.outlet. To produce a map
> representing the corresponding watersheds of all these points I thought of the
> three following approaches:
> (A)  At certain intervals (of the r.water.outlet iteration) I sort the
> previous
> calculated basins by area and use the resulting and ascending order as an
> input
> for r.patch. So the basins can not hide each other.
> (B) At certain intervals I execute r.cross for overlaying the previous basins.
> (C) I use r.mapcalc in every iteration step with an expression like
> "allbasins = allbasins +
> if(isnull(allbasins),basin<x>,if(allbasins>=1&&basin<x>==1,<newBasinID>,allbas
> ins))"
> where allbasins is initially a "novalue" raster.
> All methods above are working right, but have the same lack: the performance -
> too slow!
> Remember that the working raster has an extent of 10000x10000 pixel. The
> single
> calculated basins and their extents compared to entire drainage raster are
> very
> small (see the attachment). While the duration of r.water.outlet is barely
> acceptable, the merging step (regardless of the technique in A, B or C) takes
> too long.
> What do you think about the three approaches for a script in Python and how
> can
> i minimize the performance problem when bringing the basins together within a
> large area? Many thanks for any advice!
> Regards,
> Christian.
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
