[GRASS-user] Re: [OSGeo-Discuss] use of color palettes with vector
data
Stéphanie Faroux
stephanie.faroux at meteo.fr
Tue May 20 04:02:05 EDT 2008
Hello Markus,
Now I will use the grass user list as you suggest.
Thank you for your answer; as i'm a recent grass user, could you confirm
this is what to do to get your update:
svn checkout https://svn.osgeo.org/grass/grass-addons grass-addons
#Subsequent updates:
svn up
Thank you
Best regards
Stéphanie
Markus Neteler a écrit :
> Hi Stéphanie,
> (this is best asked on the GRASS user list).
> Last Saturday I have added in d.vect: support for z height (geometry)
> colors, so no more need to add an attribute table and such:
> http://lists.osgeo.org/pipermail/grass-dev/2008-May/037911.html
> You can easily colorize 3D points/lines/polygons:
> d.mon x0
> d.vect -z lidar1map3d zcol=gyr
> (the r.colors color tables apply; use the GUI instead of CMD line of course).
> The update is in GRASS-SVN.
> (second try, small screenshot was rejected by this list)
> Best
> Markus
> On Mon, May 19, 2008 at 6:58 PM, Stéphanie Faroux
> <stephanie.faroux at meteo.fr> wrote:
>> Hello,
>> I'd like to know if it's possible to use color palettes with vector data.
>> I have point vector data (for example, altitude), and i'd like to apply a
>> palette automatically, on the symbols representing the value points (like
>> circles).
>> I saw i can define a new column GRASSRBG in the dbf table associated to my
>> vector layer. But it's not very easy, because i have 10000 points in my
>> area. I could set values of the palette with rules on the z column, but it
>> would be nicer if existing palettes could be chosen.
>> Thank you
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080520/07cf3ba3/stephanie_faroux.vcf
