[GRASS-user] segmentation fault r.li on 6.3.1svn (subject errata
corrige)
Leonardo Lami
lami at faunalia.it
Wed May 21 06:02:10 EDT 2008
Hi all,
I'm testing r.li.x on 6.3.1svn but I have some problems.
I run r.li.setup setting a moving windows 60x60 cells in a region with a
resolution 5x5 meters as sampling area. The region have this values:
projection: 99 (Transverse Mercator)
zone: 0
datum: rome40
ellipsoid: a=6378388 es=0.006722670022333322
north: 4817400
south: 4812130
west: 1644645
east: 1651180
nsres: 5
ewres: 5
rows: 1054
cols: 1307
cells: 1377578
The sampling area file have this contenents:
SAMPLINGFRAME 0|0|1|1
SAMPLEAREA -1|-1|0.0569259962049|0.0459066564652
MOVINGWINDOW
When I run r.li.shannon I have this output:
GRASS 6.3.1svn (Toscana):~ > r.li.shannon
map=uso_primavera_2005 at mipi_analisi conf=vicarello
output=uso_primavera_2005_vicarello_shannon
[5]+ Done r.li.setup
Segmentation fault
WARNING: Can't open header file for [uso_primavera_2005 in (null)]
CHILD[pid = 6124]: unable to open 2+ mask ... continue without!!!
GRASS 6.3.1svn (Toscana):~ > WARNING: Can't open header file for
CHILD[pid = 6123]: unable to open 2+ mask ... continue without!!!
CHILD[pid = 6122]: unable to open 2+ mask ... continue without!!!
CHILD[pid = 6121]: unable to open 2+ mask ... continue without!!!
CHILD[pid = 6120]: unable to open 2+ mask ... continue without!!!
CHILD[pid = 6119]: unable to open 2+ mask ... continue without!!!
CHILD[pid = 6118]: unable to open 2+ mask ... continue without!!!
CHILD[pid = 6117]: unable to open 2+ mask ... continue without!!!
CHILD[pid = 6116]: unable to open 2+ mask ... continue without!!!
CHILD[pid = 6115]: unable to open 2+ mask ... continue without!!!
The problem seems to be in the header raster file...but it doesn't seem
particular strange:
proj: 99
zone: 0
north: 4817400
south: 4812130
east: 1651180
west: 1644645
cols: 1307
rows: 1054
e-w resol: 5
n-s resol: 5
format: 2
compressed: 1
Have someone any ideas?
Thank you very much for your help!
Leonardo
