[GRASS-user] segmentation fault r.li on 6.3.1svn (subject errata corrige)
Markus Neteler neteler at osgeo.org
Wed May 21 18:31:01 EDT 2008
Hi Leo,
I have tested with your data which you sent offlist to me in GRASS 6.4.svn:
no problem - works.
Markus
On Wed, May 21, 2008 at 12:02 PM, Leonardo Lami <lami at faunalia.it> wrote:
> Hi all,
> I'm testing r.li.x on 6.3.1svn but I have some problems.
> I run r.li.setup setting a moving windows 60x60 cells in a region with a
> resolution 5x5 meters as sampling area. The region have this values:
> projection: 99 (Transverse Mercator)
> zone:       0
> datum:      rome40
> ellipsoid:  a=6378388 es=0.006722670022333322
> north:      4817400
> south:      4812130
> west:       1644645
> east:       1651180
> nsres:      5
> ewres:      5
> rows:       1054
> cols:       1307
> cells:      1377578
> The sampling area file have this contenents:
> SAMPLINGFRAME 0|0|1|1
> SAMPLEAREA -1|-1|0.0569259962049|0.0459066564652
> MOVINGWINDOW
> When I run r.li.shannon I have this output:
> GRASS 6.3.1svn (Toscana):~ > r.li.shannon
> map=uso_primavera_2005 at mipi_analisi conf=vicarello
> output=uso_primavera_2005_vicarello_shannon
> [5]+  Done                    r.li.setup
> Segmentation fault
> WARNING: Can't open header file for [uso_primavera_2005 in (null)]
> CHILD[pid = 6124]: unable to open 2+ mask ... continue without!!!
> GRASS 6.3.1svn (Toscana):~ > WARNING: Can't open header file for
> CHILD[pid = 6123]: unable to open 2+ mask ... continue without!!!
> CHILD[pid = 6122]: unable to open 2+ mask ... continue without!!!
> CHILD[pid = 6121]: unable to open 2+ mask ... continue without!!!
> CHILD[pid = 6120]: unable to open 2+ mask ... continue without!!!
> CHILD[pid = 6119]: unable to open 2+ mask ... continue without!!!
> CHILD[pid = 6118]: unable to open 2+ mask ... continue without!!!
> CHILD[pid = 6117]: unable to open 2+ mask ... continue without!!!
> CHILD[pid = 6116]: unable to open 2+ mask ... continue without!!!
> CHILD[pid = 6115]: unable to open 2+ mask ... continue without!!!
> The problem seems to be in the header raster file...but it doesn't seem
> particular strange:
> proj:       99
> zone:       0
> north:      4817400
> south:      4812130
> east:       1651180
> west:       1644645
> cols:       1307
> rows:       1054
> e-w resol:  5
> n-s resol:  5
> format:     2
> compressed: 1
> Have someone any ideas?
> Thank you very much for your help!
> Leonardo
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
