[GRASS-user] interpolate raster map
Hamish hamish_b at yahoo.com
Thu May 22 09:58:09 EDT 2008
> Thanks for the answer - I am in the process of trying it
> out. But:
> When I try to use r.resamp.rst, I get the error message
> "Input map
> resolution differs from current region resolution!". I
> thought that
> r.resamp.rst is doing exactly that - changing the
> resolution?
hmmm, not sure. you are right it should be built for changing the resolution. or maybe the result looks ok anyway.
I don't know the module very well, maybe ask on the main grass list?
good luck,
Hamish
