[GRASS-user] interpolate raster map
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu May 22 10:02:26 EDT 2008
On Thu, 22 May 2008, Hamish wrote:
>> Thanks for the answer - I am in the process of trying it
>> out. But:
>> When I try to use r.resamp.rst, I get the error message
>> "Input map
>> resolution differs from current region resolution!". I
>> thought that
>> r.resamp.rst is doing exactly that - changing the
>> resolution?
> hmmm, not sure. you are right it should be built for changing the resolution. or maybe the result looks ok anyway.
As far as I know it works "the wrong way round", i.e. different from the
other resampling modules - you actually run it with the resolution set to
that of the original map (g.region rast=mapname), and set the desired new
resolution using command-line options.
Paul
