[GRASS-user] GUI equivalent of command
H.S.Rai hs at raiandrai.com
Fri May 30 23:05:23 EDT 2008
On Sat, May 31, 2008 at 8:09 AM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
> here is my attempt for a smooth transition from the GUI to the command
> line:
> http://www.isprs-studentconsortium.org/assets/files/Material_reports/Volume_2_No2/CORINE_withGRASS.pdf
<snip>
> Concerning your question "Is there way to show results of commands given
> in terminal window to Map Display Screen?"
> Yes, the Output display.
Could not get it. May I ask for syntax / complete command.
With regards,
Dr. H.S.Rai
http://hs.raiandrai.com/
> I can tell you my experience shortly:
> The most difficult thing was to understand the structure of the database
> in the beginning. And using a command was indeed scary.
> But once you have:
> 1. the structure of the database on your mind (central folder > projects
>> location #one for each projection system > data sorted by GRASS
> #vector, raster, etc)
> 2. the computationa region and the grid resolution
> 3. the MASK (what is it, how it works, how to use)
> 4. the fact that you have to connect first to the database for vector
> data
> 5. the fact that when you copy from a PERMANENT mapset data in a
> user-mapset automatically an attribute table will be created coming from
> the vector data of course
> 5. the use of the Output window to see what is the result of a command
> (your question above)
> 6. some more + regular use of course
> ...then all starts to get easier and exciting.
> Maybe starting with pre-existing datasets is better so you avoid the
> very first FEAR of creating a Location.
> You might find this interview interesting and pass it over to cause
> curiosity to the students (or maybe not!)
> http://www.isprs-studentconsortium.org/assets/files/Material_reports/Volume_2_No1/GRASS-GIS_OpenInterview.pdf
> Cheers,
> Nikos
