[GRASS-user] GRASS on cluster
    Jose Miguel Martins Delgado
    jdelgado at gfz-potsdam.de
    Tue Nov  4 10:14:01 EST 2008
Dear all,
The following happens when trying to create a new location on GRASS
running on a cluster.
1. I access to the server and when I try to create a location with lat
long, GRASS never asks me about the datum and ellipsoid as it normally
does in my station GRASS.
2. After creating the location it says "But the PROJECTION information
files were not created! You must run g.setproj successfully before
projection software will work".
3. When I press crtl-C to exit the location creation menu, it says that
I exited abnormally. Howeverm this is exactly what I do successfully in
my station version.
4. I  never have the chance to run g.setproj because when I try to
access my location, GRASS does not launch and returns an error: "Error
setting region (Problem with g.region?): child process exited abnormally)"
5. A way of dealing with this is to start GRASS directly on a dummy
location, like spearfish60. Then changing the location with g.proj -c.
The problem is that, again, GRASS replies:
GRASS 6.3.0 > g.proj -c epsg=4326 location=LatLong
g.proj: error while loading shared libraries: libproj.so.0: cannot open
shared object file: No such file or directory
6. At this point I have no clue. Thanks for your help!
Jose Miguel
