[GRASS-user] GRASS on cluster
Jose A. Ruiz-Arias
jararias at ujaen.es
Tue Nov 4 13:57:33 EST 2008
Hi Jose Miguel,
two alternatives:
normally, you won't be the superuser (root) of the system. Then, you
should set the LD_LIBRARY_PATH variable in your user environment
including the lib directory of GRASS. For example, if you use bash, just
edit .bashrc in your home dir and add:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:<grass_install _dir>/lib
where <grass_install_dir> is where you have installed GRASS. Then save
it and do: source .bashrc
The another approach requires root privileges. Just add <grass_install
_dir>/lib to the file /etc/ld.so.conf (in Mandriva; in other
distributions should be something similar), save it, and run "ldconfig".
Hope this works,
Jose Miguel Martins Delgado escribió:
> Dear all,
> The following happens when trying to create a new location on GRASS
> running on a cluster.
> 1. I access to the server and when I try to create a location with lat
> long, GRASS never asks me about the datum and ellipsoid as it normally
> does in my station GRASS.
> 2. After creating the location it says "But the PROJECTION information
> files were not created! You must run g.setproj successfully before
> projection software will work".
> 3. When I press crtl-C to exit the location creation menu, it says that
> I exited abnormally. Howeverm this is exactly what I do successfully in
> my station version.
> 4. I never have the chance to run g.setproj because when I try to
> access my location, GRASS does not launch and returns an error: "Error
> setting region (Problem with g.region?): child process exited abnormally)"
> 5. A way of dealing with this is to start GRASS directly on a dummy
> location, like spearfish60. Then changing the location with g.proj -c.
> The problem is that, again, GRASS replies:
> GRASS 6.3.0 > g.proj -c epsg=4326 location=LatLong
> g.proj: error while loading shared libraries: libproj.so.0: cannot open
> shared object file: No such file or directory
> 6. At this point I have no clue. Thanks for your help!
> Jose Miguel
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
José A. Ruiz-Arias
Solar Radiation and Atmosphere Modelling Group
http://www.ujaen.es/investiga/tep220
Physics Department, University of Jaén
Campus Lagunillas, Building A3 066
23071 Jaén Spain
Tlf: +34 953 212 474
Fax: +34 953 212 838
