[GRASS-user] Rename multiple sqlite columns at once
Moritz Lennert
mlennert at club.worldonline.be
Thu Nov 6 13:59:19 EST 2008
On 06/11/08 17:37, Nikos Alexandris wrote:
> On Thu, 2008-11-06 at 11:18 +0100, Paolo Craveri wrote:
>> ciao to all
>> pay attention to spaces between column name in v.db.renamecol: no
>> spaces before and after comma.
>> Command substitution: backticks → $(....) not substantial
>> differences; the second form is easier to read and write; it is also
>> nestable (we are all used to ` ` form, but $() is better (IMHO))
>> This should work (probably):
>> db.columns test
>> key_column="cat"
>> suffix="_tmp"
>> for column in `db.columns test`; do
>> if [ "$column" != "$key_column" ]; then
>> tempcolumn=$(echo $column | awk '{print tolower($1)}')
>> tempcolumn=$tempcolumn$suffix
>> v.db.renamecol map=test layer=1 column=$column,$tempcolumn
>> lower_column=$(echo $tempcolumn $suffix| awk '{print
>> substr($1,1,length($1)-length($2))}')
>> v.db.renamecol map=test layer=1 column=$tempcolumn,$lower_column
>> fi
>> done
>> db.columns test
>> ciao
> Ciao Paolo & Moritz!
> Thank you for your assistance.
> @Moritz: I tried it but still not clean.
> # cat caps_2_lower_moritzx.sh -n
> 1 #!/bin/sh -x
> 2
> 3 key_column="cat"
> 4 suffix="\_tmp"
> 5 for column in `db.columns test`; do
> 6 if [ "$column" != "$key_column" ]; then
> 7 tempcolumn=`echo $column | awk '{print
> tolower($1)}'`
> 8 tempcolumn="$tempcolumn""\_tmp"
> 9 echo $tempcolumn
> 10 v.db.renamecol map=befliegung_copy column=
> $column,$tempcolumn
> 11 lower_column=`echo $tempcolumn $suffix | awk '{print
> 12 substr($1,1,length($1)-length($2))}'`
> # output
> block_id\_tmp
I think this is because of the quotes:
But actually, trying out your entire original script, I don't see where
the problem is. The attached version seems to work perfectly for me
(just slightly simplified from your original version):
What exactly did not work when you tried this ?
Moritz
Type: application/x-shellscript
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20081106/52efa774/change_case.bin
