[GRASS-user] r.terraflow usage (segfault)
Fri Nov 14 07:36:57 EST 2008
Markus Neteler wrote:
> On Thu, Nov 13, 2008 at 7:23 PM, Massimo Di Stefano
> <massimodisasha at yahoo.it> wrote:
> > Hi
> > i'm tring to use "r.terraflow"
> > following the help page i see :
> > r.terraflow elev=spearfish filled=spearfish-filled \
> >    dir=spearfish-mfdir swatershed=spearfish-watershed \
> >    accumulation=spearfish-accu tci=spearfish-tci
> > but i can't find any "spearfish" elevation data in the spearfish dataset
> > so i used elevation.dem insted,
> I have fixed the nonsense example to
> r.terraflow elev=elevation.10m filled=elevation10m.filled \
>     dir=elevation10m.mfdir swatershed=elevation10m.watershed \
>     accumulation=elevation10m.accu tci=elevation10m.tci
> > but i've a segfault :-/
> Me, too.
This was introduced by r34198, which was back-ported in r34205.
> This hack seems to cure the problem:
region is being allocated, but not until after that point.
Fixed in r34285.
