[GRASS-user] r.terraflow usage (segfault)
    Markus Neteler
    neteler at osgeo.org
    Fri Nov 14 10:08:45 EST 2008
On Fri, Nov 14, 2008 at 1:36 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> On Thu, Nov 13, 2008 at 7:23 PM, Massimo Di Stefano
>> <massimodisasha at yahoo.it> wrote:
>> > Hi
>> > i'm tring to use "r.terraflow"
>> > following the help page i see :
>> > r.terraflow elev=spearfish filled=spearfish-filled \
>> >    dir=spearfish-mfdir swatershed=spearfish-watershed \
>> >    accumulation=spearfish-accu tci=spearfish-tci
>> > but i can't find any "spearfish" elevation data in the spearfish dataset
>> > so i used elevation.dem insted,
>> I have fixed the nonsense example to
>> r.terraflow elev=elevation.10m filled=elevation10m.filled \
>>     dir=elevation10m.mfdir swatershed=elevation10m.watershed \
>>     accumulation=elevation10m.accu tci=elevation10m.tci
>> > but i've a segfault :-/
>> Me, too.
> This was introduced by r34198, which was back-ported in r34205.
>> This hack seems to cure the problem:
> region is being allocated, but not until after that point.
> Fixed in r34285.
backported to 6.4.svn.
Markus
