[GRASS-user] Compile grass6_devel with ffmpeg support?
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Mon Nov 24 00:23:33 EST 2008
On Mon, 2008-11-24 at 01:57 +0000, Glynn Clements wrote:
> Nikos Alexandris wrote:
> > thanks for the support. I can't *locate* the avformat.h file under my
> > system. I can't find any ffmpeg-dev package in the ubuntu repositories.
> > I even did try to compile grass after compiling ffmpeg latest source
> > code [1]. No luck.
> > There was no issue in Ubuntu 7.10 64-bit. With Ubuntu HH and now II
> > there always was a problem but I never had a closer look. Broken ubuntu
> > package or broken ffmpeg source code?
> The files are still there in the latest source code:
> http://svn.ffmpeg.org/ffmpeg/trunk/
> I don't know whether they still get installed, or where.
After updating the index-database (don't know if I use the proper
terminology here) with "sudo updatedb" I can trace them but only in the
source codes: (a) the one from the ubuntu repositories and (b) of course
the one you mention Glynn.
However, this file is not installed at least when installing ffmpeg from
the ubuntu repositories. I will give another try to compile ffmpeg from
its source... but I don't think I'll get to it these days.
Thank you, Nikos
