[GRASS-user] importing L1G-data into GRASS
rosa
rosa.marzipan at gmx.de
Mon Oct 6 11:00:16 EDT 2008
dear niels,
thanks for your answer. unfortunately it didn't solve the problem. i changed
the color table into grey and still can't use r.composite. and without that i
cannot go for anything else.
i really wonder what the problem is! the import finally worked and i do have
all the channels in my location... just can't work with them...
maybe somebody else knows what to do, before i have to go for erdas?!
rene
Am Montag 06 Oktober 2008 09:34:03 schrieb Niels Thevs:
> Dear Irene,
> when you display one channel in GRASS, it is displayed by default with a
> color scheme ranging form green to yellow or blue to red. Under Raster
> -> Manage Map Color you can change this.
> Regarding the import of Landsat images I prefer the following way,
> though not purely with open source software: Import your image with
> ERDAS and save it as img-file. img is a rather wide spread satellite
> image data format, which can be read inmediately by ERDAS, ENFI, ARC GIS
> etc. And, img.-files can be imported without any problems into GRASS.
> You even can build your location with a few clicks using an img file.
> I guess that in Potsdam there is an ERDAS Licence somewhere.
> Best regards
> Niels
> rosa schrieb:
> > hello,
> > i'm new on this list since yesterday.
> > some postgraduates are trying to introduce GRASS in our university and so
> > I'm writing one of the first thesis' with GRASS. Unfortunately nobody
> > here knows the program really well.
> > I bought a landsat scene, recieved it in hdf.L1G-format and have problems
> > importing landsat the hdf.L1G-data into GRASS. r.in.bin does
> > somehow work, but the channels it imports are severely damaged. instead
> > of having the normal black/white picture, the chanels are only green and
> > yellow and it's not possible to combine them, f.e. with r.composite.
> > does anybody know the problem?
> > warm regards from potsdam, germany
> > irene
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
