[GRASS-user] Runing grass inside Msys console
Daniel Victoria daniel.victoria at gmail.com
Thu Oct 9 07:29:19 EDT 2008
This is exactly what happened. I have the .grassrc6 in my home dir
(grass/msys/home/<username>) but the grass63 startup script is in
grass/msys/home/C/Documents and Settings/<my_name>/grass63.
I fixed this by making a symbolic link. Did not know I could just move
the script around.
Daniel
On Thu, Oct 9, 2008 at 4:39 AM, Marco Pasetti <marcopstt at gmail.com> wrote:
> Daniel,
>> I just installed WinGrass (great job by the way) but in order to run
>> GRASS inside the MSYS console I have to explicitly go to the directory
>> were grass63 is at. IOW, the grass63 startup script is not in the path
>> environment. Is it possible to put the startup script in the path
>> environment, along with other utilities like gdalinfo?
> Normally, if you launch the GRASS MSYS Console command from the Start->GRASS
> menu, you will automatically open a MSYS session "ready" to start GRASS with
> the paths set to all the needed utilities. This said, the installer has a
> bug (already fixed in trunk, but not still "built" with a new a binary
> release), that sometimes makes it fail to correctly define the username on
> XP machines: that implies that the grass63 script is not put in the folder
> where it should be (that is .\GRASS\msys\home\"YOUR_USERNAME").
> Please, check if you have the grass63 script and the .grassrc6 file in
> .\GRASS\msys\home\"YOUR_USERNAME"; if not, look for them in
> .\GRASS\msys\home (and subfolders) and move them to
> .\GRASS\msys\home\"YOUR_USERNAME".
> Regards,
> Marco
