[GRASS-user] r.reclass using pipe from r.stats?
    Dawn Abbot
    whiterabbot1 at yahoo.com
    Fri Oct 10 14:26:16 EDT 2008
I am trying to create a single color map to overlay the elevation map to show the different elevations.  I clicked on properties of my raster map and was able to create the color map by choosing psudocolors but I do not have any luck when I pick custom color map.  Does anyone have any suggestions?
----- Original Message ----
To: Milton Cezar Ribeiro <miltinho.astronauta at gmail.com>
Cc: grass-user at lists.osgeo.org
Sent: Friday, October 10, 2008 10:47:08 AM
Subject: Re: [GRASS-user] r.reclass using pipe from r.stats?
Milton Cezar Ribeiro wrote:
> I have a raster map with all categories (~50)
> and I have about 500 spatial subsets of the same
> original map. As is expected, each of spatial subset
> map have less categories than the original map.
> I can check the list of categories for each subset
> map using r.stats. But I need to generate a new
> set of maps with the spatial range of original map,
> but keeping only those classes of my original map.
> Just supose that "r.stats mysubset1" result something
> like:
> 2
> 4
> 9
> 11
> 43
> So, I would like that my new map with my full spatial
> range keep only these 5 categories, and all other
> categories come to be "no data".
> I know if I generate a rule file with
> 2=2
> 4=9
> 11=11
> 43=43
> I can get the desired results, but as the number
> of spatial subsets is very large I would like turn it
> more operational.
> Is there a suggestion of how can I do this using pipe like
> r.stats mysubset1 | r.reclass mysubset1 mysubset1_fullrange rules= -??
    r.stats mysubset1 | awk '{print $1,"=",$1} ; END {print "* = NULL"}' | r.reclass ...
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081010/3b2675e3/attachment.html
