[GRASS-user] How to import NASA SRTM DEM data into VTK
Elvis Dowson
elvis.dowson at mac.com
Sun Oct 12 04:59:53 EDT 2008
How can I import NASA SRTM DEM data, stored in a file format
called hgt, into VTK-5.3.x?
Apparently the *hgt file format can just be renamed to *.dem, but the
contents of the file are stored in a format called GTOPO30 DEM, I think.
When I opened the SainteHelens.dem file supplied with the VTK Data
package, I can see that it consists of ascii values and is human-
readable.
However, when I look at a NASA SRTM file, it appears to be some sort
of binary file format.
Here is an example of a NASA SRTM file ftp://e0srp01u.ecs.nasa.gov/srtm/version2/SRTM3/Australia/S34E150.hgt.zip
vtkDEMReader will not directly work with the NASA SRTM file.
Has someone implemented a reader that will read in the NASA SRTM file?
If someone can help point me in the right direction, I can even spend
some time and try to implement a new vtkSRTMReader class.
Best regards,
Elvis Dowson
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081012/19291d85/attachment.html
