[GRASS-user] delete features with v.edit
Moritz Lennert
mlennert at club.worldonline.be
Tue Oct 14 08:43:39 EDT 2008
On 14/10/08 14:36, christian Brandt wrote:
> Dear list,
> I try to delete features from a vector theme using v.edit.
> After specifying the attribute column to choose with v.db.connect
This sentence is not clear: v.db.connect allows you to connect a map to
a table indicating the column of the table which contains the category
values of the vector features you are linking to. You cannot "specify a
column to chose".
> I was entering the following:
> v.edit map=geb_emiss_KP at PERMANENT tool=catdel ids=Geb053362
> There comes the message within the the output of v.edit:
> Tool catdel requires option cats
Two issues:
- tool=catdel deletes only the category value, not the feature itself,
if you want to do the latter, use tool=delete
- ids= is not what you want to use (you have to know the internal ids of
vector features), but rather where=, so something like this:
v.edit map=geb_emiss_KP at PERMANENT tool=delete
where="SelectColumn=='Geb053362'"
where SelectColumn is the column which contains your selection criteria.
Moritz
