[GRASS-user] Re: Reading 'ecw'-files (Joop Goedbloed)
Jarle Pedersen mybigb at gmail.com
Wed Oct 15 08:20:42 EDT 2008
I believe you need to set the resolution of the project to 450m before
importing. I saw you have "g.region vect=gbknH02 at venlo" in your script. If
this is this the vector with 1000m resolution that would be the problem.
Using "g.region nsres=450 ewres=450" instead should fix it unless you use
a geographical projection.
Jarle J. Pedersen
