[GRASS-user] Re: Reading 'ecw'-files (Joop Goedbloed) (Jarle
Pedersen)
Joop Goedbloed
jlgoedbloed at hetnet.nl
Wed Oct 15 12:58:21 EDT 2008
Hello Usersgroup
Jarle Pederson wrote:
I believe you need to set the resolution of the project to 450m before
importing. I saw you have "g.region vect=gbknH02 op venlo" in your script. If
this is this the vector with 1000m resolution that would be the problem.
Using "g.region nsres=450 ewres=450" instead should fix it unless you use
a geographical projection.
Jarle J. Pedersen
Projection = RD (Rijks Driehoekmeting) X,Y,Z Jarle J. Pedersen
Ok vect=gbknH02 op venlo is the 1000x1000m vector map want to read ~9 different ecw. maps to match with that region.
I have change the scripts like this
"g.region vect=gbknH02 op venlo align=207900_367650_75_2007.red op venlo" (one of the imported esc-maps)
Like Markus Neteler said.
The scrips run a longer time and the result is very good every thing ok.
Thanks
Joop Goedbloed
