[GRASS-user] Re: r.resamp.stats max method not working as expected
Markus Neteler
neteler at osgeo.org
Thu Oct 16 05:34:06 EDT 2008
On Wed, Oct 15, 2008 at 5:39 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Glynn Clements wrote:
> Implemented in r33888 (in 7.0).
> The aforementioned comment in the Wiki still stands. min/max aren't
> actually weighted, so the behaviour of those aggregates with a
> perfectly aligned grid is "unstable" (i.e. the exact result may depend
> upon miniscule rounding errors) even when -w is used.
Jamie,
do you want need this in 6.4 (hence, backport)? Or are you fine
with GRASS 7? According to Glynn it's a slightly incompatible
change which isn't 100% in line with our backport policy.
Markus
