[GRASS-user] Re: r.resamp.stats max method not working as expected
Jamie Adams
jaadfoo at gmail.com
Thu Oct 16 12:29:05 EDT 2008
I think 7 is fine. My current approach is working well enough.
Thanks!
On Thu, Oct 16, 2008 at 2:34 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Oct 15, 2008 at 5:39 PM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
> > Glynn Clements wrote:
> > Implemented in r33888 (in 7.0).
> > The aforementioned comment in the Wiki still stands. min/max aren't
> > actually weighted, so the behaviour of those aggregates with a
> > perfectly aligned grid is "unstable" (i.e. the exact result may depend
> > upon miniscule rounding errors) even when -w is used.
> Jamie,
> do you want need this in 6.4 (hence, backport)? Or are you fine
> with GRASS 7? According to Glynn it's a slightly incompatible
> change which isn't 100% in line with our backport policy.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081016/764b00ec/attachment.html
