[GRASS-user] "Re: Contents of grass-user digest... HOW TO INSTALL GRASS"
Van PD Tri vpdtri at ctu.edu.vn
Mon Oct 20 01:51:31 EDT 2008
Hi to all,
Thanks Nikos!
I have just practised your guidance (i.e. > (a) You can launch grass
from a terminal by typing: grass -gui)
After doing it, the following error appear:
dtat at dtat-desktop:~$ grass -gui
The program 'grass' is currently not installed.  You can install it by typing:
sudo apt-get install grass
bash: grass: command not found
I wonder why because I did run the command
And it looks like I was doing successful.
Could you please give me further help.
Best regards,
Tri Van
Quoting Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> On Mon, 2008-10-20 at 00:40 +0700, Van PD Tri wrote:
>> Hi to all,
>> I think I can install GRASS already. At the end, I receive a note like:
>>   │ Operating System Distributor License for Java v1.1 (DLJ)
>>   │ Operating System Distributor License for Java version 1.1 (DLJ)
>>   │ SUN MICROSYSTEMS, INC. ("SUN") IS WILLING TO LICENSE THE JAVA
>> PLATFORM    ▒
>>   │ STANDARD EDITION DEVELOPER KIT ("JDK" - THE "SOFTWARE") TO YOU
>> ONLY UPON  ▒
>>   │ THE CONDITION THAT YOU ACCEPT ALL OF THE TERMS CONTAINED IN
>> THIS LICENSE  ▒
>>   │ AGREEMENT (THE "AGREEMENT").  PLEASE READ THE AGREEMENT
>> CAREFULLY.  BY    ▒
>>   │ INSTALLING, USING, OR DISTRIBUTING THIS SOFTWARE, YOU ACCEPT
>> ALL OF THE   ▒
>>   │ TERMS OF THE AGREEMENT.
>> However, I have no idea where it is installed and how to launch
>> GRASS?! Could you please send any help?
>> Best regards,
>> Tri Van
> Hi!
> I don't think(=know if) that the "Java" message has anything to do with
> GRASS.
> (a) You can launch grass from a terminal by typing:
> gass -gui
> (b) Or you want to add a new menu item (Ubuntu specific: System >
> Preferences > Main Menu > New Item  -- then enter "grass -gui" withouth
> the qiuotes in the "command" field, give some a name for your new
> "launcher" and a description if you like. *** Decide under which Menu
> you want/will place the "grass" launcher ***).
> You might (...probably) want to read the following thread(s):
> http://www.nabble.com/grass-gis-td19636258.html
> http://www.nabble.com/grass-gis.-td19636354.html
> Kind regards, Nikos
This message was sent using IMP, the Internet Messaging Program.
