[GRASS-user] "Re: Contents of grass-user digest... HOW TO
INSTALL GRASS"
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Mon Oct 20 14:24:04 EDT 2008
Hi!
(Assuming you work with Ubuntu Hardy Heron 8.04)
I would remove everything related with grass and re-install again (using
Jachym's repository [1]). Open a terminal and...
1. execute the following command:
sudo apt-get purge grass
2. According to [1] edit the sources.list file which is under /etc/apt:
sudo gedit /etc/apt/sources.list
3. Add the 2 lines in the end of the file for example (although you can
add them anywhere else) as procided in [1]:
deb http://les-ejk.cz/ubuntu hardy multiverse
deb-src http://les-ejk.cz/ubuntu hardy multiverse
4. Save and close the sources.list file
5. Get Jachym's gpg signature
wget -q http://les-ejk.cz/pgp/jachym_cepicky-gpg.pub -O - | sudo apt-key
add -
6. Update and Upgrade
sudo apt-get update && sudo apt-get upgrade
7. install grass with:
sudo apt-get install grass
8. Launch grass with:
grass -gui
Good Luck, Nikos
[1] http://www.les-ejk.cz/ubuntu/
