[GRASS-user] How to install Grass into Ubuntu
Matt B mattslists at gmail.com
Mon Oct 20 05:31:15 EDT 2008
Hello list,
I'm using Grass on ubuntu 8.04. Weird thing is that unless I run it "sudo
grass" I get a bunch of errors (and it's unusable) related to grass not
having the correct permissions to write to where I keep the data (ie the
users home directory). It's not a show stoppper at the moment and only
slightly annoying. I'm not sure why this is but I have some ideas to hunt
down when I get time. I used the standard ubuntu install and assume its
something to do with the ubuntu setup script.
Matt
On Mon, Oct 20, 2008 at 7:10 PM, Jhon Ortiz <eljhonjhon at hotmail.com> wrote:
>  ***  RE: [GRASS-user] *How to install Grass into Ubuntu
> > > sudo apt-get install grass
> > The offical Ubuntu repositories are a bit outdated. A more updated
> > repo is the one from Jachym: http://www.les-ejk.cz/ubuntu/
> > The Gutsy one has Grass 6.3.0, updated to May 2008.
> Im working with Ubuntu 7.10 Gutsy and in this repositories
> not is available the version 6.3.0, the laster version in this
> repositories is 6.2.2 (http://www.les-ejk.cz/ubuntu/).
> The people who working in Ubuntu and want to work with
> other version have to compile it. It's not a so hard task.
> http://grass.osgeo.org/wiki/Compile_and_Install
> > If you want newer versions... you need to compile it. It's not a so
> > hard task, and we can give advices.
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Ahora llévate lo mejor de MSN y Windows Live, en tu móvil<http://serviciosmoviles.es.msn.com/>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081020/a5f818e8/attachment.html
