[GRASS-user] generalize a map of points
Wolf Bergenheim
wolf+grass at bergenheim.net
Mon Oct 20 17:08:10 EDT 2008
On 20.10.2008 20:31, José María Michia wrote:
> After some drawbacks to update "GRASS," I have achieved some results.
> - The command d.labels does not show anything. It seems to run
> normally, without error, but the active monitor does not show
> anything.
> - Working with the GIS Manager ", the labels are displayed well.
> However, after exporting the "Display Map" to "raster" labels
> disappear from the image (JPG, PPM, and others).
> - I got maps with labels using "ps.map". See files attached.
> labels_sa_new.pdf : show labels obtained with the command:
> $ v.label.sa map=ciudades_region labels=ciudades_v_label_sa_new
> column=LOCALIDAD font=arial overlap=inhab
Hmm that is really strange...
Could you send me that city map (off list), so that I can test a bit. I
did try it and it worked for me. Also caopy.paste all commands you used
to generate the maps.
Thanks for testing,
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
