[GRASS-user] Wrong projection info after importing Geotif
Agustin Lobo
aloboaleu at gmail.com
Thu Oct 23 14:51:11 EDT 2008
Markus,
Markus Neteler wrote:
>> But I do not
>> think that this is a matter of concern. The point is that
>> the geographic info displayed by gdal for npp.tif is correct
>> (the "90d 2'30.00"S" problem is not in this file)
> Can you please post this output, or, better, the npp.tif file?
> It's hard to test without.
The output is the one I had in my original message, I reproduce it here
and the file is at http://aloboaleu.googlepages.com/forMarkus
Thanks for your help!
Agus
$ gdalinfo npp.tif
Driver: GTiff/GeoTIFF
Files: npp.tif
Size is 1440, 572
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235629972,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,85.000000000114397)
Pixel Size = (0.250000000000200,-0.250000000000200)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-180.0000000, 85.0000000) (180d 0'0.00"W, 85d 0'0.00"N)
Lower Left (-180.0000000, -58.0000000) (180d 0'0.00"W, 58d 0'0.00"S)
Upper Right ( 180.0000000, 85.0000000) (180d 0'0.00"E, 85d 0'0.00"N)
Lower Right ( 180.0000000, -58.0000000) (180d 0'0.00"E, 58d 0'0.00"S)
Center ( 0.0000000, 13.5000000) ( 0d 0'0.00"E, 13d30'0.00"N)
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
