[GRASS-user] Wrong projection info after importing Geotif
Markus Neteler neteler at osgeo.org
Fri Oct 24 16:25:37 EDT 2008
Agustin,
I could reproduce the problem...:
GRASS 6.4.svn (latlong_tbe_climate):~ > r.in.gdal npp.tif out=npp
ERROR: region for current mapset is invalid
       line 9: <e-w resol: 0>
       run "g.region"
# Now I reset the location which was still messed up from the previous
# try to import npp_CruP_All_fine_geo.tif:
GRASS 6.4.svn (latlong_tbe_climate):~ > g.region -dp
projection: 3 (Latitude-Longitude)
zone:       0
datum:      wgs84
ellipsoid:  wgs84
north:      50N
south:      30N
west:       5E
east:       20E
nsres:      1
ewres:      1
rows:       20
cols:       15
cells:      300
# Voilà - the import works again:
Projection of input dataset and current location appear to match
 100%
<npp> created
r.in.gdal complete.
I assume that a 'g.region -d' which cure it also at your end.
Markus
