[GRASS-user] Wrong projection info after importing Geotif
Agustin Lobo
Agustin.Lobo at ija.csic.es
Sat Oct 25 04:48:15 EDT 2008
Thanks Markus,
but this should not be the correct way for r.in.gdal to work,
should it? I mean that the default is reading the
the geotif with its own region, which should not
be interfered by the current region unless you use
the -o option. Am I wrong?
Anyway, my problem for applying your solution is
described in message
http://lists.osgeo.org/pipermail/grass-user/2008-October/047198.html
(I set up the default region using qgis and, by some reason, was wrong
and cannot modify it)
Agus
Markus Neteler wrote:
> Agustin,
> I could reproduce the problem...:
> GRASS 6.4.svn (latlong_tbe_climate):~ > r.in.gdal npp.tif out=npp
> ERROR: region for current mapset is invalid
> line 9: <e-w resol: 0>
> run "g.region"
> # Now I reset the location which was still messed up from the previous
> # try to import npp_CruP_All_fine_geo.tif:
> GRASS 6.4.svn (latlong_tbe_climate):~ > g.region -dp
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 50N
> south: 30N
> west: 5E
> east: 20E
> nsres: 1
> ewres: 1
> rows: 20
> cols: 15
> cells: 300
> # Voilà - the import works again:
> Projection of input dataset and current location appear to match
> 100%
> <npp> created
> r.in.gdal complete.
> I assume that a 'g.region -d' which cure it also at your end.
> Markus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
