[GRASS-user] Re: georectify of a scanned map (Torsten Eckart)
Mohammed Rashad rashadkm at gmail.com
Sun Oct 26 13:15:48 EDT 2008
> start grass from xy location in terminal.
run i.group (select your existing group)
i.target
i.points (already exists in ur case)
i.rectify (without -ca flag)
if the error repeats when run from terminal
 you should goto grassdata directory and (ctrl+H ,view hidden files) then u
can see .tmp directory you should delete .tmp directory from both xy and
projected location mapset folder
delete directory. and start grass again.
Rashad
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081026/128fb069/attachment.html
