[GRASS-user] Wrong projection info after importing Geotif
Markus Neteler
neteler at osgeo.org
Tue Oct 28 04:41:02 EDT 2008
On Tue, Oct 28, 2008 at 9:28 AM, Agustin Lobo <Agustin.Lobo at ija.csic.es> wrote:
> Markus, I already did use -d, I copy the output below. But
> the problem that worries me most is not that the default region
> be wrong, but that r.in.gdal gets confused and interfered by
> the default or active region while I think that the only geographic info
> that should
> matter for r.in.gdal is the one in the geotiff file,
> which is correct.
> $ g.region -d
> $ g.region -p
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 90N
> south: 90S
> west: 180E <<-
> east: 180E <<-
This is no good.
West should be 180W.
This means that the DEFAULT_WIND contains
bad data. How did you create the location (sorry I forgot).
Another magic could be to add -e to r.in.gdal below.
But it seems that the location definition is inappropriate.
Markus
> nsres: 0:14:25.153538
> ewres: 0:21:36
> rows: 749
> cols: 1000
> cells: 749000
> $ r.in.gdal input=/media/mifat32/MASTER_ICTA2007_2008/2008b/npp.tif
> output=npp
> GRASS_INFO_MESSAGE(18845,1): Projection of input dataset and current
> location appear to match
> $ g.region rast=npp
> $ g.region -p
> GRASS_INFO_ERROR(18874,1): region for current mapset is invalid
> GRASS_INFO_ERROR(18874,1): line 9: <e-w resol: 0>
> GRASS_INFO_ERROR(18874,1): run "g.region"
> Thanks,
> Agus
> Markus Neteler wrote:
>> Agus,
>> On Mon, Oct 27, 2008 at 10:17 PM, Agustin Lobo <Agustin.Lobo at ija.csic.es>
>> wrote:
>>> Markus,
>>> I made the mapset using the QGIS plugin Grass /New mapset.
>>> I'm not sure if I made something wrong or it was a problem of
>>> the plugin(I'll clarify this), but the fact is that I ended up with
>>> this (wrong) region:
>>> ~$ g.region -p
>>> GRASS_INFO_ERROR(9537,1): region for current mapset is invalid
>>> GRASS_INFO_ERROR(9537,1): line 9: <e-w resol: 0>
>>> GRASS_INFO_ERROR(9537,1): run "g.region"
>> Yes (@devs: suggest the -d flag?)
>>> First problem is that I cannot fix this region as explained in
>>> http://lists.osgeo.org/pipermail/grass-user/2008-October/047198.html
>> If you looks closely, there was suggested:
>> g.region -d
>> Did you really run that (g.region set to default region)?
>> GRASS doesn't automatically recover from a illegal
>> region setting.
>> Then I suppose that it will work.
>> Markus
>>> Second problem is that I run r.in.gdal as I mentioned to import the file
>>> that I've put
>>> in http://aloboaleu.googlepages.com/forMarkus
>>> and get a wrong region for the raster as well:
>>> output=npp
>>> ~$ g.region rast=npp
>>> ~$ g.region -p
>>> GRASS_INFO_ERROR(19559,1): region for current mapset is invalid
>>> GRASS_INFO_ERROR(19559,1): line 9: <e-w resol: 0>
>>> Nevertheless, according to gdalinfo, the geotif file is correct
>>> (see my last message for the gdalinfo output).
>>> Probably, r.in.gdal would have worked fine if the default region had
>>> been
>>> correct, but this is no the point (I think). r.in.gdal should set the
>>> region
>>> for the raster according to the geotiff settings, which are correct.
>>> So there is something wrong with r.in.gdal?
>>> Thanks for your patience!
>>> Agus
>>>> Agus,
>>>> On Sat, Oct 25, 2008 at 10:48 AM, Agustin Lobo
>>>> wrote:
>>>>> Thanks Markus,
>>>>> but this should not be the correct way for r.in.gdal to work,
>>>>> should it? I mean that the default is reading the
>>>>> the geotif with its own region, which should not
>>>>> be interfered by the current region unless you use
>>>>> the -o option. Am I wrong?
>>>> since I still don't know which steps you really did (apparently
>>>> you created the location from the GeoTIFF file?)
>>>> I don't know how to help. Maybe I just missed that.
>>>>> Anyway, my problem for applying your solution is
>>>>> described in message
>>>>> (I set up the default region using qgis
>>>> OK, but in QGIS, what did you do to set up the default region?
>>>>> and, by some reason, was wrong and cannot modify it)
>>>> To reproduce it, I would need the steps in a detailed way...
>>>> (say, due to work overload I am most motivated with the
>>>> full procedure :-).
>>>> Markus
>>> Dr. Agustin Lobo
>>> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>>> LLuis Sole Sabaris s/n
>>> 08028 Barcelona
>>> Spain
>>> Tel. 34 934095410
>>> Fax. 34 934110012
>>> email: Agustin.Lobo at ija.csic.es
>>> http://www.ija.csic.es/gt/obster
> Dr. Agustin Lobo
> 08028 Barcelona
> Spain
> Tel. 34 934095410
> Fax. 34 934110012
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
