[GRASS-user] v.profile ??
Francesco Mirabella mirabell at unipg.it
Tue Oct 28 09:36:29 EDT 2008
Hi all,
does anyone know if there is a way of drawing a vertical profile from a
3d vector point map? For example from earthquakes location data which
are typically 3d vector points? It seems to me that it should be
something corresponding to r.profile, but for vectors (v.profile??).
Also, typical profiles (sections) of such data require a "thickness" of
the section to be set in order to project the vectors from a given
distance onto the section. Again this is typical for earthquakes
distributions.
any hints?
thanks in advance
Francesco
