[GRASS-user] v.profile ??
Maris Nartiss maris.gis at gmail.com
Tue Oct 28 10:21:56 EDT 2008
Hello Francesco.
You are really lucky :) I'm implementing v.profile right now. It's
"almost" working - it needs some final touches and documentation
before it's ready for release. Currently it does not support 3d maps,
but I will put it on my TODO list. Still it will not be in 6.4.0.
Francesco, if You need some vector profiling tool right now, I can
send it to You offlist. Otherwise just hope that I will have free time
to work on GRASS code :)
Maris.
2008/10/28, Francesco Mirabella <mirabell at unipg.it>:
> Hi all,
> does anyone know if there is a way of drawing a vertical profile from a
> 3d vector point map? For example from earthquakes location data which
> are typically 3d vector points? It seems to me that it should be
> something corresponding to r.profile, but for vectors (v.profile??).
> Also, typical profiles (sections) of such data require a "thickness" of
> the section to be set in order to project the vectors from a given
> distance onto the section. Again this is typical for earthquakes
> distributions.
> any hints?
> thanks in advance
> Francesco
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
