[GRASS-user] v.profile ??
Francesco Mirabella
mirabell at unipg.it
Tue Oct 28 10:44:39 EDT 2008
Hi Maris,
thanks for your message, that's funny! :-) I am very happy that
v.profile will exist!
I do believe that a growing number of people can get advantages of such
a tool, maybe especially geologists and seismologists who currently work
with 3D vector data (also for example borehole data).
It would be nice if you could send it to me in the meantime, I will try
to install it and try it.
best wishes
Francesco
Maris Nartiss wrote:
> Hello Francesco.
> You are really lucky :) I'm implementing v.profile right now. It's
> "almost" working - it needs some final touches and documentation
> before it's ready for release. Currently it does not support 3d maps,
> but I will put it on my TODO list. Still it will not be in 6.4.0.
> Francesco, if You need some vector profiling tool right now, I can
> send it to You offlist. Otherwise just hope that I will have free time
> to work on GRASS code :)
> Maris.
> 2008/10/28, Francesco Mirabella <mirabell at unipg.it>:
>> Hi all,
>> does anyone know if there is a way of drawing a vertical profile from a
>> 3d vector point map? For example from earthquakes location data which
>> are typically 3d vector points? It seems to me that it should be
>> something corresponding to r.profile, but for vectors (v.profile??).
>> Also, typical profiles (sections) of such data require a "thickness" of
>> the section to be set in order to project the vectors from a given
>> distance onto the section. Again this is typical for earthquakes
>> distributions.
>> any hints?
>> thanks in advance
>> Francesco
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
